Need outdoor antenna for 1231 AP
spfister336
Level 2
Level 2
I've got a project where I need to set up some old, spare 1231 APs at one of our locations. We need to have some coverage right outside one area of the building. What's a good antenna to use for this? We'd probably have the AP inside and just mount the antenna outside.
Scott Fella
You can just use any of the omni directional antennas for outdoor, but make sure you don't use one with a high gain. Look at the air-ant2506
-Scott
