Showing results forĀ
Search instead forĀ
Did you mean:Ā
Need to assign Static for APS 2602
in our project there 98 APs are registered in wlc 5760 i need to assign Static IP for Each APS.
is there command line method to assign Static IP for 2602 APS
2 Accepted Solutions
Rasika Nayanajith
Why do you need to assign static IP for APs ?
Since it is not a recommended practice to give static IP, i asked that.
Anyway if you want to make it static you can use below CLI command
5760#ap name <ap_name> static-ip ip-address <ap_ip_address> netmask <netmask_value> gateway <gateway_ip>
Below is an example.
5760#ap name AP01 static-ip ip-address 192.168.100.1 netmask 255.255.255.0 gateway 192.168.100.254
If you know all the ap name, you can create all config lines in notepad & then apply it in one go to save some time.
Rasika
*** Pls rate all useful responses ***
Rasika Nayanajith
Thanks Rasika,
it requirement to assign static IPS in our Project we have already apply for wism controller APS
Rasika
