Showing results forĀ
Search instead forĀ
Did you mean:Ā
Need to be able to report on a specific WLAN
spfister336
Level 2
Level 2
I've been asked to generate some report data on a specific WLAN, a limited access WLAN that was added recently. We need to be able to report on "Average and Peak Number of clients (Total)" and "Total Bytes Transferred (all  APs)" on a per site basis. The sites involved mainly use 4402 and 5508 WLCs managed by our WCS server. Is there anything on WCS where we can easily get this information (on a monthly basis).
George Stefanick
Yes, in WCS check reports. You can use one of the can reports or make custom ones.
__________________________________________________________________________________________
ā€Ž"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
