Need to configure different SSIDs on same VLAN on 1142
baskervi
We're having a problem with interference in the B/G range due to the large number of access points owned by other companies in a fairly small area. The various laptops keep deauthenticating, which is causing problems with applications. I'd like to configure two SSIDs on the same VLAN but have them broadcasted on different frequencies. The AP complained about the configuration when I added the Company5.8 SSID below stating another SSID can't be added to a VLAN, but it shows in the configuration. Does any one have a suggestion as to what I can try? Thanks
interface Dot11Radio0
 no ip address
 no ip route-cache
 encryption vlan 1 mode ciphers aes-ccm
 encryption vlan 3 mode ciphers aes-ccm
 ssid Moleculera Labs
 ssid Moleculera Labs-guest
 antenna gain 0
 mbssid
 channel least-congested 2412 2437 2462
 station-role root
interface Dot11Radio0.1
 encapsulation dot1Q 1 native
 no ip route-cache
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
 bridge-group 1 spanning-disabled
interface Dot11Radio0.3
 encapsulation dot1Q 3
 no ip route-cache
 bridge-group 3
 bridge-group 3 subscriber-loop-control
 bridge-group 3 block-unknown-source
 no bridge-group 3 source-learning
 no bridge-group 3 unicast-flooding
 bridge-group 3 spanning-disabled
interface Dot11Radio1
 no ip address
 no ip route-cache
 encryption mode ciphers aes-ccm
 antenna gain 0
 dfs band 3 block
 mbssid
 channel dfs
 station-role root
interface Dot11Radio1.1
 no ip route-cache
 bridge-group 1
interface Dot11Radio1.3
 no ip route-cache
 bridge-group 3
2 Accepted Solutions
Amjad Abdullah
Please post the full configuration (including SSID's config).
Try also to remove the command
from under radio 1 (5 GHz)
Rating useful replies is more useful than saying "Thank you"
Little fine tuning on configuration.
Only suggested change is to use wpa2 if your ap supports it. This can be done with below command.
under dot11 SSID add below line.
authentication key-management wpa version 2
If device does not support version v2 then modify the encryption for all vlan to support TKIP with below command.
 encryption vlan 1 mode ciphers aes-ccm tkip
Since your are specifying encryption for each vlan separately you can remove the encryption statement under radio 1 like Amjed mentioned.Either way it won't harm you
Hope that helps.
Najaf
5 Replies 5
mohanak
Try this :
If you use VLANs on your wireless LAN and assign SSIDs to VLANs, you can create multiple SSIDs by using any of the four security settings on the Express Security page. However, if you do not use VLANs on your wireless LAN, the security options that you can assign to SSIDs are limited because of the limited Express Security page encryption options. Without VLANs, encryption settings (WEP and ciphers) apply to an interface, such as the radio, and you cannot use more than one encryption setting on an interface. For example, when you create an SSID with static WEP with VLANs disabled, you cannot create additional SSIDs with WPA authentication because they use different encryption settings. If you find that the security setting for an SSID conflicts with another SSID, you can delete one or more SSIDs to eliminate the conflict.
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/1140/autonomous/getting_started/guide/ap1140aut_getstart.html
Amjad, if I delete "encryption mode ciphers aes-ccm" what kind of encryption will the AP use?
Mohanak, I'm using the same encryption settings with VLANs
Here is the more complete configuration:
version 12.4
no service pad
service password-encryption
hostname COMPANY-AP
no logging console
enable secret 5 *
no aaa new-model
no ip domain lookup
ip domain name COMPANY.local
dot11 syslog
dot11 ssid COMPANY-2.4
   vlan 1
   authentication open
   mbssid guest-mode
   wpa-psk ascii 7 *
dot11 ssid COMPANY-5.8
   vlan 1
   authentication open
   mbssid guest-mode
   wpa-psk ascii 7 *
dot11 ssid COMPANY-guest
   vlan 3
   authentication open
   guest-mode
   mbssid guest-mode
   wpa-psk ascii 7 *
bridge irb
 no ip address
 no ip route-cache
 ssid COMPANY-2.4
 ssid COMPANY-guest
 antenna gain 0
 mbssid
 station-role root
 no ip route-cache
 bridge-group 1
 no ip route-cache
 bridge-group 3
 no ip address
 no ip route-cache
 ssid COMPANY-2.4  (Want this to be COMPANY-5.8)
 ssid COMPANY-guest
 antenna gain 0
 dfs band 3 block
 mbssid
 channel dfs
 station-role root
 no ip route-cache
 bridge-group 1
 no ip route-cache
 bridge-group 3
interface GigabitEthernet0
 no ip address
 no ip route-cache
 duplex auto
 speed auto
 no keepalive
interface GigabitEthernet0.1
 no ip route-cache
 bridge-group 1
interface GigabitEthernet0.3
 no ip route-cache
 bridge-group 3
interface BVI1
 ip address 192.168.67.3 255.255.255.0
 no ip route-cache
ip default-gateway 192.168.67.1
ip http server
ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
 exec-timeout 30 0
 password 7 *
 login local
end
COMPANY-AP#
Hope that helps.
Najaf
The encryption will be used as it is already configured.
The command:
describes the encrypiton for vlan 1 (there is another command for vlan 3 as well).
That should be enough.
now, you are also using the command
under the Radio1. This command can be used when you are not using vlans. try to delete this and ope that will improve something.
Amjad
Amjad Abdullah
