Network computers not showing up
Eric Kemsley
Level 4
Level 4
Cisco 2504 wlc, 1142n ap, windows radius server.
When I click on Network, the only computer that shows up is mine. If I am hardwired then everything shows up (Servers, other workstations). Is this a problem with the radius server or something on the controller?
TIA,
Eric
Stephen Rodriguez
On the WLC, make sure that you have broadcast forwarding enabled.  Should be Contrller > General tab
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Stephen Rodriguez
HTH,
Steve
HTH,
Steve
Thanks! That did the trick.
