network mesh MAP
Dhikra Marghli
Level 9
Level 9
Hello
my work that i have 4 acces point 1815 and we would to work in mesh mode
so my question .
if they not support mode mesh so it client wirless can  connect with them withou problem ??
how does the traffic work between acces point  MAP ???
how long distance betwenn AP MAP ??
thanks
3 Accepted Solutions
1. As i said earlier, 1800 series AP dont support mesh mode means it will not work as MAP.
2. In a Cisco wireless backhaul network, traffic can be bridged between MAPs and RAPs. This traffic can be from wired devices that are being bridged by the wireless mesh or CAPWAP traffic from the mesh access points. This traffic is always AES encrypted when it crosses a wireless mesh link such as a wireless backhaul.
3. More info about distance, check this guide:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-8/b_mesh_88/b_mesh_88_chapter_01.html#ID494
Dont forget to rate helpful posts
Please read this guide:
https://www.cisco.com/c/en/us/td/docs/wireless/technology/mesh/8-3/b_mesh_83/Mesh_Deployment_Modes.html
Here are the list of Indooe and outdoor Mesh APs:
Cisco Indoor Mesh Access Points
Cisco Aironet 1600 Series Access Points
Cisco Aironet 1700 Series Access Points
Cisco Aironet 2600 Series Access Points
Cisco Aironet 2700 Series Access Points
Cisco Aironet 3500 Series Access Points
Cisco Aironet 3600 Series Access Points
Cisco Aironet 3700 Series Access Points
Cisco Aironet 1530 Series Access Points
Cisco Aironet 1540 Series Access Points
Cisco Aironet 1550 Series Access Points
Cisco Aironet 1560 Series Access Points
Cisco Aironet 1570 Series Access Points
Cisco Industrial Wireless 3700 Series Access Points
Cisco outdoor mesh access points comprise of the Cisco Aironet 1500 series access points. The 1500 series includes 1572 11ac outdoor access points, 1552 and 1532 11n outdoor mesh access points, and the newer 1540 and 1560 11ac wave 2 series..
MAP is configured as bridge mode.
Client will decide the best coverage AP to connect.
Don't forget to rate helpful posts
11 Replies 11
Sandeep Choudhary
As per my knowledge 1800 series dont support mode. May be in future it will but not at the moment.
dont forget to rate helpful posts
NO !my  question on suppose we work with 1815 so i have three question !!
i have three acces point MAP newtork wirless with them and not bridge with them !!
So   witch acces point MAP that client wirless connected with !!  last MAP or first MAP !!
and witch mode acces point MAP !!??
thanks in adavnce
i need reference please
i have three acces point MAP WIRLESS  not MAP bridge
so my question
when client move from AP to AP map , witch acces point  MAP first to connect !!
witch mode AP  to be nework mesh  wirless AP to wirless AP and not acces point MAP bridge to bridge
thanks
you don't unterstand ly question
Toplogy : Point-to-Point Wireless MAP : betwwenn AP MAP is wireless conection and  not  Point-to-Point Wireless MAP  bridge
===>  witch mode that i configured in acces point MAP to be nework mesh !!??
so , when client move from MAP to MAP , my question what is  access point  MAP that client connect first !!
Hello
Topology mesh
the three  ap map are moved to a mountain place and a single ap RAP  in an adminstration !!
so  that is we make toplogy mesh acces point
we are more  person connected in mountain place
So  , if we have ap  model 1500 in moutain  place SO  , client can connectet with   connection wirless through  model AP  1500  !!?,
Hello
Topology mesh
yes client will connect to MAP.
