10-10-2011 07:14 AM - edited 07-03-2021 08:53 PM
HI Guys
Hope you well
I am currently supporting an engineer onsite remotely and have come across a strange problem .
I have installed a few controllers but none of them have behaved in this manner.
The model is a WLC 5508-50k9 model wireless controller and software 7.0.98.0
I have seen as per installation guideline that amber means th following
Distribution ports 1-8 Off: Not present.
Green: Indicates SFP port is active and link is established.
This mean that so coherent fault lies as follows on Layer 1&2 .
The switch port light does not go green either.
We have used both xover and straight but no luck
The controller is using GLC - T to connect to the switch
Any idea guys
10-10-2011 08:13 AM
Are you using a Cisco GLC-T?
10-11-2011 12:38 AM
Yes as stated below in my original text
I am using Glc-T
10-11-2011 05:27 AM
But are they CISCO ? Also are you using any transivers anywhere in line to this link ?
