Wireless NICs
Roger Alderman
Level 5
Level 5
Hi All
I have a customer who wants to have the PC wireless NIC card disabled if an ethernet cable is plugged into the PC and is active.
Does anyone know if this is possible or if there wireless client utilities that do this?
Thanks as always.
Roger
Surendra BG
Whats the Wireless driver used?? on the same disable the Wired tick mark and this may help you!!
Surendra
Surendra BG
Hi Surendra
I actually want to disable the wireless NIC if the ethernet port is plugged in.
Roger
I am telling the same thing..
I am using CSSC as the wireless client driver to connect to the Wireless.. when i connect the lan cable my wireless gets off!!!
This is done like this..
LAPTOP >> My network connections >> Right Click on the LAN >> Properties >> Enable the CLient service used for Wireless.
This will do it!!
Surendra
Surendra BG
Roger,
I blogged about this subject a bit ago. You may find this helpful
http://www.my80211.com/client-labs/2009/9/23/disable-your-wireless-nic-when-plugged-into-a-wired-connecti.html
