New wireless configuration advice
mfender
We have 2 sites that are under 1000' apart with clear line of sight. I would like to bridge the 2 LAN's together. In the past I would have used a 350AP and a 350BR... can anyone recommend what AP/Bridges I should use today for this config?
scottmac
Level 10
Level 10
A 1200 with an appropriate high(er) gain antenna should do the trick.
If the antenna is on the roof, a small yagi would suffice. If you have a clear window-to-window view, you may even be able to get by with a (db patch antenna on each end.
The best thing would be to do a site survey (or have one done). There are many factors and only a good site survey and / or an on-site evaluation by a knowledgable and quallified person would be worthy of trust.
Good Luck
Scott
Thank you for your reply... Just a quick question. I thought the 1200's couldnt be used as a bridge?
