Newbie Help
kwaboy
Frequent Visitor
Frequent Visitor
I have got a Cisco Air Cap 1602 Wireless AP
I have it connected to a switch, I can see it on my router page but I can't get into the web page to configure it.
I can see it when I console in with Putty , this is where Im stuck, I just want to use it on my home network, please can someone talk me through how to do it, ie what to type into putty to get it to connect to my network.
I just need it to extend my current network
As I said Im a newbie so please be gentle
Thanks in advance
13 Replies 13
 You need to it. When you open up putty and try to connect to it using ssh or telnet does it ask for user and password.
 Default values is Cisco Cisco.
 You can also set it to factory default using the button on the back side.
-If I helped you somehow, please, rate it as useful.-
Hi, yes i can log on with the username but that’s as far as I can get the ap just cycles and doesn’t connect what commands do I need to give ??
Send to me the command show version please.
Ok, how do I show that ??
Copy from AP and paste here.
what do I type into putty to show the info ?
show version
Ok. Cheers
What I am trying to figure out here is if you have and Autonomous AP or lighwelight AP. As per the LED behavior you described, it seems to me that you have an lightweight AP with you and if thats is true you need to convert it to Autonomous.
 The show version command can show it by revealing the AP partnumber which is something like k9w8 or k9w7.
 To show this information you just need to login in on the and type " show version".
 Can you do that?
ROM: Bootstrap program is C1600 boot loader
BOOTLDR: C1600 Boot Loader (AP1G2-BOOT-M) LoaderVersion 15.2(2)JAX, RELEASE SOFTWARE (fc1)
AP6c20.560e.401a uptime is 1 minute
System image file is "flash:/ap1g2-rcvk9w8-mx/ap1g2-rcvk9w8-mx"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco AIR-CAP1602I-E-K9 (PowerPC) processor (revision A0) with 98294K/32768K bytes of memory.
Processor board ID FGL1706Z5L9
PowerPC CPU at 533Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 7.4.1.37
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 6C:20:56:0E:40:1A
Part Number : 73-14671-04
PCA Assembly Number : 000-00000-00
PCA Revision Number :
PCB Serial Number : FOC16493ZNF
Top Assembly Part Number : 800-38552-01
Top Assembly Serial Number : FGL1706Z5L9
Top Revision Number : A0
Product/Model Number : AIR-CAP1602I-E-K9
As I suspected you have a capwap/lightweight AP and you need  to convert if you want to use at home without an WLC.
Great, so how do I do that please
You need to get an autonomous AP image and convert. The image can be downloaded from Cisco site but require contract.
 How to convert is full of information non the internet.
 This example here might help
https://www.google.com.br/amp/s/mrncciew.com/2012/10/20/lightweight-to-autonomous-conversion/amp/
