No Access/Connection AIR CAP1532i-E-K9 - no Console output First Time Configuration
i want to configure an Access Point AIR CAP15321i-E-K9 for the first time and with no Controller.
The Access Point is connected to a POE Cisco SG50 Switch .
I can ping the AP (DHCP IP) , but i don`t get the GUI or a Console Output .
The LED is blinking green.
If there any POE Settings or a special Console Cable or something else i have to use/do ?
Thank for Help
7 Replies 7
Divya
CAPWAP APs does not have remote session(SSH/Telnet/HTTPS/HTTP) support by default.
The only way to access the AP is through Console cable. If you don't have a WLC in the network then you need to convert this AP to Mobility Express so that you can manage as well as serve the wireless clients.
Divya
thank you for reply.
Can i download a version of Mobility Expess without Service Contract or must i have a service contract ?
Because i get the message that a service contract is required when i want to download Mobility Express.
Thank you.
Please provide me your CCO id and I'll publish the image to you.
Divya
Sven Grund
sven.grund.axsysnet
sven.grund@axsysnet.de
Thank you
My Bad!
I thought it is AP1832 model :(
AP1532 supports Autonomous mode and it is very simple to convert. Please follow the below steps:
AP#capwap ap autonomous
Convert to Autonomous image. Proceed? (yes/[no]):
thank you.
I don´t get an output on the Console/Serial Port only a black screen.
Must i do special Settings or use a special ConsoleCable ?
