No inter-controller and intra-controller roaming with 802.1x authentication.
Hi! Help solve the problem, I can not get roaming on Android smatrfone with 802.1x ep-sim authentication. Using WLC 5508 with external radius server. In what could be the problem?
Scott Fella
I don't know if you will find your answer here as many probably don't use EAP-SIM. All I could say is debug your client and look to see if the device is doing a full reauth or not. Compare it to a device that is working as if its the only device that's not working, well its points to an issue with that device. Could be the supplicant that's the issue.
-Scott
