No SSID are Broadcasting
jmarshman
I was wondering if someone out there could help me with a problem with our WLAN.  We recently received our WLC 5508, AP and switches to setup our WLAN but I'm having trouble getting it all to work.  It's been months since the course and I'm having trouble troubleshooting the problem.
I've setup the WLC, AP and switches and I have network connectivity to all.  The WLC see's my AP and I have all my WLAN and interfaces configured (SSID broadcast is enabled) but I still don't see any SSID coming from the AP.
Help!
Jason,
     the defaul AP group will only broadcast for WLAN 1-16.  Your WLAN are running as 104,105 and 199.  You need to create a new AP group, and add the WLAN(s) to it.  Then when you put the AP in the group it should start working.
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
23 Replies 23
blakekrone
Level 4
Level 4
Have you setup any AP groups? What version code?
edit...Scott beat me to it, but yes check to make sure your 802.11a and/or 802.11b/g networks are enabled under the Wireless section.
To make things easy I only have one AP up so far and the operational status is "up"
Scott Fella
Make sure you have the 802.11an and 802.11bgn radios enabled. If your using ap groups, make sure you have added the AP's and SSIDs to the correct ap group. You do see all you AP's up and radios show up or down?
Scott Fella
Sent from my iPhone
-Scott
Operational status of the ap is "up" and I'm not using AP groups.
Your SSID enabled?
-Scott
Can you post the output of show wlan , show ap config 802.11a summary, show ap config 802.11b summary?
Is it an ap with external anetnna?  Do you have antenna's installed on that AP?  If so, I don't know if they are dual mode or not, but make sure the antennas are on the correct antenna ports.  Usually the blue bot is the 5ghz.
-Scott
We have  AIR-CAP3502I-A-K9 devices with internal antenna.
(Cisco Controller) >show wlan summary
Number of WLANs.................................. 3
WLAN ID  WLAN Profile Name / SSID               Status    Interface Name
104      CPHO_WLAN / CPHO                       Enabled   cpho_int
105      EOC_WLAN / EOC                         Enabled   eoc_int
199      Guest_WLAN / Guest                     Enabled   guest_int
(Cisco Controller) >show ap config 802.11a summary
AP Name                SubBand RadioMAC            Status     Channel   PwLvl   SlotId
AP2894.0f39.1516          -    0c:85:25:df:07:80   ENABLED    149       1       1
(Cisco Controller) >show ap config 802.11b summary
AP2894.0f39.1516          -    0c:85:25:df:07:80   ENABLED    11        1       0
here is a more detailed show wlan
WLAN Identifier.................................. 199
Profile Name..................................... Guest_WLAN
Network Name (SSID).............................. Guest
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Number of Active Clients......................... 0
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 1800 seconds
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ guest_int
Multicast Interface.............................. Not Configured
--More-- or (q)uit
WLAN ACL......................................... unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
Quality of Service............................... Silver (best effort)
Scan Defer Priority.............................. 5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
IPv6 Support..................................... Disabled
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Drop
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ Global Servers
--More-- or (q)uit
   Accounting.................................... Global Servers
   Dynamic Interface............................. Disabled
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Disabled
      WPA2 (RSN IE).............................. Enabled
         TKIP Cipher............................. Disabled
         AES Cipher.............................. Enabled
                                                               Auth Key Management
         802.1x.................................. Disabled
         PSK..................................... Enabled
         CCKM.................................... Disabled
         FT(802.11r)............................. Disabled
         FT-PSK(802.11r)......................... Disabled
FT Reassociation Timeout......................... 20
FT Over-The-Air mode............................. Enabled
FT Over-The-Ds mode.............................. Enabled
CCKM tsf Tolerance............................... 1000
--More-- or (q)uit
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   H-REAP Local Switching........................ Disabled
   H-REAP Local Authentication................... Disabled
   H-REAP Learn IP Address....................... Enabled
   Client MFP.................................... Optional
   Tkip MIC Countermeasure Hold-down Timer....... 60
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Mobility Anchor List
WLAN ID     IP Address            Status
Well looks like it should be working... maybe a bad AP.  I would try a different one and see.
-Scott
Jason,
Steve
HTH,
Steve
Good catch, I was just looking at that myself when I saw the config. I've seen that before with people wanting to match the WLAN ID to your VLAN ID. Doesn't work out that well unless you create the ap groups!
I'm going to create a new AP group and try it again.  I'll keep you posted.
I'd also like to mention that the training I took was with the 4400 series running older code, thus making the traing manuals useless.
