Non Bridge Interface will not work
philip.bonner
Community Member
Alright So, I am using a Cisco 871W router and currently have this config:
version 12.3
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
ip dhcp excluded-address 10.11.11.1 10.11.11.2
ip dhcp excluded-address 10.11.12.1 10.11.12.2
ip dhcp pool Vlan1Pool
import all
network 10.11.11.0 255.255.255.0
dns-server 192.168.0.1
default-router 10.11.11.1
domain-name LocalWired
lease 4
ip dhcp pool Vlan2Pool
import all
network 10.11.12.0 255.255.255.0
default-router 10.11.12.1
domain-name LocalWireless
lease 4
ip ips po max-events 100
no ftp-server write-enable
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
shutdown
interface FastEthernet2
no ip address
shutdown
interface FastEthernet3
no ip address
shutdown
interface FastEthernet4
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Dot11Radio0
no ip address
encryption vlan 2 mode ciphers tkip
ssid WLan2
vlan 2
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 0 passforcisco
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.2
encapsulation dot1Q 2
interface Vlan1
description "VLan for Wired Ports"
ip address 10.11.11.1 255.255.255.0
ip nat inside
interface Vlan2
description "Wireless LAN"
ip address 10.11.12.1 255.255.255.0
ip nat inside
ip classless
no ip http server
no ip http secure-server
control-plane
line con 0
no modem enable
transport preferred all
transport output all
line aux 0
line vty 0 4
scheduler max-task-time 5000
end
So the DHCP works just fine for the Fast Ethernet Interfaces but the Radio interface doesn't seem to work. I want to have 2 Vlans, 1 for the wireless and 1 for the wired as well as having them both on different subnets (doesn't matter the value) can anyone point me in the direction I need to go? I'd like to not have to bridge anything for that seems easier. Thanks
bwalchez
Level 8
Level 8
Your configuration seems to be correct for me. But is the client associating without IP address. I mean client will associate with least connectivity. Also, I am not sure about "ip nat inside" command. I think this configuration might be a problem for wireless network.
