non-web-auth guest authentication with an anchor controller
dmh
Level 5
Level 5
Is it possible to terminate non-web-auth WLANs on an anchor controller?
For example, you want to segregate particular WLAN access but still have encryption using WPA2-PSK or WPA2-ENT with 802.1x etc.
Thanks.
weterry
Level 4
Level 4
The auto-anchor feature should work for any wlan/security as far as I know. Just make sure your wlans are configured identically between the controllers.
