Not enough nvram memory in AP
kian_hong2000
I encounter one issue in AP. Not sure why the directory of nvram does not have any file and cannot write memory to the AP.
AP#wr
%No memory available
%No memory availablestartup-config file open failed (Not enough space)
AP#dir nvram:
Directory of nvram:/
%Error calling getdents for nvram:/ (Unknown error 89)
5 Replies 5
Leo Laohoo
Errr ... It should be "dir flash:".
abersven
What does 'show startup' show?
/André
There is configuration in the startup. However, once i reload the AP the configuration will be lost.
Not sure why cannot save the configuration in the AP
What is the output to the command "dir flash:"?
abersven
The routers NVRAM might be faulty and if so you need an RMA and that is a issue that must be solved through TAC.
You can try the following first. Just press enter to confirm:
ROUTER#write erase
Erasing the nvram filesystem will remove all configuration files! Continue? [confirm]
[OK]
Erase of nvram: complete
ROUTER#write memory
Building configuration...
[OK]
ROUTER#
Above you see how the router should respond.
/André
