not goin
maged altwaiti
we have WLC 5508 S.W ver 7.6.110.0
and  .AP 1602 i
suddenly ap can not goin with WLC
error massge
*Dec 4 06:14:22.139: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Dec 4 06:14:23.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.9.0.10 peer_port: 5246
*Dec 4 06:14:23.399: %DTLS-5-ALERT: Received FATAL : Certificate unknown alert from 10.9.0.10
*Dec 4 06:14:23.399: %CAPWAP-3-ERRORLOG: Bad certificate alert received from peer.
*Dec 4 06:14:23.399: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.9.0.10:5246
*Dec 4 06:14:23.399: %CAPWAP-3-ERRORLOG: Invalid event 40 & state 3 combination.
*Mar 1 00:01:27.455: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar 1 00:01:28.055: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
how i can solve it ?
regard<<<
17 Replies 17
Mark Elsen
 - FYI : https://www.cisco.com/c/en/us/support/docs/field-notices/639/fn63942.html
    The controller software version installed is ancient ; as per https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html
             use https://software.cisco.com/download/specialrelease/2702eede2b47a5c3bb40795bbe836af6
    Then you can also use the workarounds from the field notice : ap cert-expiry-ignore {mic|ssc} enable
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
where i execute  ap cert-expiry-ignore {mic|ssc} enable?
Do it in
Cli of wlc
MHM
                                      >...where i execute  ap cert-expiry-ignore {mic|ssc} enable?
  On the controller CLI but  you need to upgrade first according to my initial reply because that command is only available starting from 8.3.x
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Dose this workaround solve the problem if the MIC is expired in both WLC and AP?  OR it just solve the problem if the MIC of AP expired?
I think the AP not validation the expire date of WLC cert.
Only WLC do that validate
MHM
Both:
It takes effect on the WLC immediately (for expired AP cert).
It takes effect on the AP after the AP has downloaded the new software version, and joined the WLC to get the config update from the WLC (for expired WLC cert).
That's why you must follow all the steps, in the correct order, to get it fully fixed.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
Rich R
You need to follow the steps in the field notice carefully.
1. Turn off NTP and set WLC date/time back to before the certs expired - this is a temporary workaround.
2. Upgrade the WLC to 8.5.182.11.  Because you are using such an old version it would be best to upgrade to 8.0.152.0 first and then upgrade to 8.5.182.11
3. Then enter the commands as advised by Marce (they are not supported on earlier code)
4. Allow all the APs to download the new software and the new commands from the WLC
5 When all APs are updated with new code and new config then you can re-enable NTP on the WLC to operate with correct time.
maldafee
Frequent Visitor
Frequent Visitor
Both
maged altwaiti
my WLC 5508 - 7-6-110
what command i can use it to solve problem until upgrade WLC to 8.5?
                 >my WLC 5508 - 7-6-110
                 >what command i can use it to solve problem until upgrade WLC to 8.5?
   None, you really need those upgrade(s) I mentioned to implement the workaround provided earlier ,
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Did you read the field notice or the summary steps I already provided above?
Did you read my reply above summarising the steps?
