01-17-2023 06:31 AM
hi all! I push into the AP ME patch, went through the setup wizard, then connected to my WiFi, and in the network settings of the macbook, it can be seen that this is a 2.4GHz network, but if I try to create a network on my own only 5GHz, more than one client does not see it, I Couldn't find an answer on any forum, maybe someone can help?
AP: 2802i
patch: AIR-AP2800-K9-ME-8-10-151-0
help me pls =((
01-17-2023 06:51 AM
Can you post below :
show sysinfo
show wlan summary
check - config rf-profile create
01-17-2023 06:56 AM
If more than one clients can't see it is becuase some of them can, so check client specifications to see if they support 5GHz band, or the channels you are using, or the Wi-Fi generation they support, ...
02-18-2023 04:52 AM - edited 02-18-2023 04:54 AM
Can any clients see the 5GHz SSID?
Is the country correctly configured and matching the regulatory domain of the AP? (you did not provide the full AP model details)
https://www.cisco.com/c/dam/assets/prod/wireless/wireless-compliance-tool/index.html
ps: update to 8.10.183.0 to make sure you're running latest code with all available bug fixes. Next release due out soon.
