NTP settings on AP 1142N
Hi.
I have a problem with my AP,s , they have the wrong clock time.
My controller (WISM2) have the NTP server set and is works fine. But all the AP (1142N) associated to the controller is not using this NTP server settings, and the clock is running 2 hour wrong.
How can get the NTP settings from the controller to work on all my AP ?
Johan
Rasika Nayanajith
AP always show UTC time. R u in UTC-/+2hrs time zone? Then it is no problem.
Rasika Nayanajith
Thank you
Then i have to accept this config
Jatin Katyal
I agree with Rasikanayanajith, the behavior you're seeing is due to the WLC's being configured with timezone offset. Since the AP has no way to set its timezone, it will always use UTC.
~BR
Jatin Katyal
**Do rate helpful posts**
~Jatin
your welcome:)
~BR
Jatin Katyal
~Jatin
