Number of WLAN using same SSID on 2504 controller
walterp
Good day
From an old post I have found that the 2504 cannot support more than 16 WLAN's, does this mean I will not be able to run multiple vlans using the same SSID with this controller?
Walter
5 Replies 5
Leo Laohoo
The 2504 can only support up to 16 SSIDs.
Thanks Leo, does this mean I have to configure multiple ssid's if I want to have multiple vlans because it will not allow me to create multiple wlans (1 - 16) using the same ssid and security settings?
You can create up to 16 SSID on a 2504.  Each SSID can be "tied" to a single dynamic interface or a group interface.
Yes I am aware of this but I only want to create 1 ssid to be used for all vlans. The problem is that when I create more than 1 WLAN it will not allow the same ssid and security config, this means that I cannot have 4 vlans sharing the same ssid as the documentation states in order to do this you have to create WLAN's starting greater than 17 and the 2504 does not support anything higher than 16.
You can create an Interface Group and then tie it to a single SSID.
