ODBC Connection Problems
sknorr
Level 3
Level 3
I have some clients connected to a 1200AP with WEP and no authenication. These machines are having a problem keeping a ODBC connection. I don't know if this is due to latency on the WLAN or if there are any know issues with ODBC and WLANs. This isn't a problem for anyone on our wired network. If anyone have any ideas that would be great.
scottmac
Level 11
Level 11
What version and rev of code (IOS / VxWorks)?
What kind of NICs?
What version of client software are you using?
What kind of signal strength and signal quality are you getting at a typical client location?
Did you do a site survey?
Gotta know ....
Scott
