Odd Aironet 1310 problem
rpettersen
Level 2
Level 2
Hi !
Trying to get a Aironet 1310 (AIR-BR1310G-E-K9)working as it should, but see a stange problem after each re-load
This is config before re-load :
interface Dot11Radio0
ssid XXXXXXXXX
authentication open
infrastructure-ssid
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0
36.0 48.0 54.0
rts threshold 4000
station-role workgroup-bridge
bridge-group 1
bridge-group 1 spanning-disabled
And after re-load :
ssid XXXXXXXXX
authentication open
infrastructure-ssid
cca 0
36.0 48.0 54.0
rts threshold 4000
bridge-group 1
As you can see IOS is adding "cca 0" in configuration, and then the wireless configuration doesn't work. Just doing a "no cca" and then I see the 1310 is assosiated with the AP.
Anybody have seen this problem ?
Also trying to upgrade from 12.2(15)JA to 12.3(2)JA,
but then the unit freeze and I have to do a flash recovery back to 12.2.15. When I look into the 12.3.2 tar file, then I only see firmware for one radio and looking into 12.2.15 tar file, then I see firmware for 3 radios types.
rpettersen
Level 2
Level 2
Hi !
According to cisco, this is a known bug :
Resolved Caveats in 12.3(2)JA:
CSCed46039, CSCeg18102-Clear Channel Assessment (CCA) value no longer reverts to 0 after bridge reboots
So now I have to solve the upgrade problem.
