wireless LAN
gbabade
Community Member
HI,
could anyone out there pls help on what paticular product to use when deploying a wireles LAN FOR ABT 30 nodes that already has a wired LAN and the new wireless integrating with it ,,, The building is a three floor premises ,, with an installed LAN existing ,,, pls traet as urgent
RGDS
GBENGA
sbilgi
Level 11
Level 11
You can get this from some of the casestudies given under the link http://www.cisco.com/en/US/products/hw/wireless/ps458/prod_case_studies_list.html
sushilk
Level 5
Level 5
Hi Gbenga,
WLAN is a shared medium. So all the users will be sharing same bandwitdth. 802.11a and g gives up to 54Mbps while 802.11
I would suggest you to use Cisco Aironet 1230AG Series Access Points as it comes with external antenna which will give you better coverage area according to your requirement.
