Oid to view clients connected to AP
mplaksin0
Hello, anyone can help me or know an implementation of an OID to view the number of connected clients per Access-Point? I am using a 5508 WLC
+5 for resolving your own problem
Rating useful replies is more useful than saying "Thank you"
9 Replies 9
mplaksin0
Finaly i solve the probleme using 1.3.6.1.4.1.14179.2.1.1.1.38.(APIndex)
And i get the index from SNMPv2-SMI::enterprises.14179.2.1.1.1.2.1 = STRING:
LOL @ AA ... +5
Keep up the good work
+5 to you as well George. ^_^
Which is solution for this issue ?
Hi I have the same problem but I have not been resolved I can help out?
I'm trying to get this thing with Solar Winds
Please find article on this website which explain and give a Template to use for monitoring WLC with PRTG.
https://kb.paessler.com/en/topic/75561-how-can-i-monitor-a-cisco-wlc-deployment-with-prtg
I am not good at writting code, but I would like to insert the solution propose by mplaksin.
Can someone be able to insert this OID 1.3.6.1.4.1.14179.2.1.1.1.38.(APIndex)
into the Template?
This would answer all my needs of surveillance from my WLC. Thank you for your help!
into the Template?
Hi. It's not working on a WLC 5508 with 8.2 firmware.
Any help on this?
Flavio.
