Open Roaming - Capturing Identity
cbishop
Community Member
I am researching using open roaming and I found cisco documentation on how to enable open roaming on meraki devices.  It all seems straight forward but where I am lost is how do I capture the info of the authorized user? If a user authenticates with a google ID on my network how do I find out what the google ID is?  If I cannot find out what that user ID is how do I bring up a captive portal?
Rich R
1. The whole idea of Openroaming is to log the user in (authentication) so there would be no captive portal.
2. You don't need a user ID for a captive portal.  Captive portals are driven by IP and MAC address for identity.  In fact 99% of the time you don't know the user ID when presenting a captive portal.
For more info on Openroaming in general see https://wballiance.com/openroaming/
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
Rich R
cbishop
Community Member
whoops. didn't mean to accept as solution.
So we want to prompt the connect user to allow us to have their email address for future contact.  We currently do that through Open Wifi.  We also give users the option of installing a Passpoint profile to connect securely next time.  We have the ability to wall garden the user on secure wifi to prompt them with a captive portal to capture additional details.  We achieve this by passing back Radius Attributes that trigger the AP to move the user into a wall garden.  With Open Roaming we don't handle the authentication, in fact I don't know if there is any option for hooking into this process so we can tell the AP not to allow the authenticated user online but instead move them to a walled garden.
