Outdoor Use
n-khouri
Community Member
I need to use the AP350 for outdoor, is there any special enclosures I can use , I need some recommendation please .
this outdoor area is very noisy , its an airplane parking.
when the airplane engine starts , the signalstarts going on and off ..
kmarrero
Level 8
Level 8
For weatherproofing your AP, you can look for a NEMA enclosure. These enclosures will not block radio interference. If you are having issues with the airplane engines, you may need to raise the antennas up to try and bypass the RF interference.
