outdoor
ahmedalshami
Level 3
Level 3
dear
i want to connect to sites the distance between this sites is 4 km the location is in desert which kind off 2.4 ghz can we use
please advice
ericgarnel
Level 11
Level 11
Take a look at the Cisco 1300 series
Here is a link that explains a very similar situation to yours
http://wireless.gumph.org/articles/longrangelink.html
ialexhassi
Community Member
In a desert environment, there are generally fewer obstacles like buildings and trees that can interfere with wireless signals, which can be advantageous for establishing long-distance connections. However, other factors such as atmospheric conditions, terrain, and potential interference from other electronic devices must be considered.
For a distance of 4 km, you'll likely need some high-power equipment or specialized antennas to maintain a stable connection. In the 2.4 GHz frequency range, you could consider using equipment like high-gain directional antennas and long-range wireless access points or bridges.
Here are some options you might consider:
  1. High-Gain Directional Antennas: Directional antennas focus the signal in a specific direction, increasing the effective range of your wireless connection. Yagi or parabolic grid antennas are common choices for long-distance point-to-point links.
  2. Wireless Bridges: Wireless bridges are devices specifically designed for creating point-to-point connections over long distances. They often come with built-in high-gain antennas and can operate in the 2.4 GHz band.
  3. Outdoor Access Points: Some outdoor access points are designed to cover larger areas and can be configured to create point-to-point links. These access points often have higher transmit power and better weatherproofing to withstand outdoor environments.
  4. Wireless Repeaters: In some cases, you might need to use wireless repeaters to extend the range of your connection. However, each repeater introduces additional latency and potential points of failure, so they should be used sparingly.
When setting up a long-distance wireless link, it's important to carefully plan the installation, consider factors like line of sight, Fresnel zone clearance, and potential sources of interference. Additionally, you may need to check local regulations regarding the use of wireless equipment and ensure that you have the necessary permissions to operate within the desired frequency band.
