Overlapping
Thomas Ley
Community Member
I have a remote location with 4 AIR-CAP3502E-A-K9 (AP01,AP02, AP03, AP04)  ver 2.0 with 8 SSIDs   2 ea. AIR-ANT5135DG-R (DISABLED) and 2 ea. AIR-ANT2422DG-R (ENABLED)  I have no b clients and few g clients ( 4 ea. LXE XV6 used very lightly) and a very few N clients (mostly laptops maybe 1 month for 1/2 hr.) I have a 4404 controller ver. 7.0.98.0
AP03              MAC C4:0A:CB:DF:AD:6F      Channel 36  (Rate 6,9,12, 18, 24, 36, 48, 54)
AP03             "                                        "6E      Channel 36  "                                                     "
AP03             "                                        "61       Channel 11  (Rate 2, 5.5, 6, 9, 11, 12, 18, 24, Ext 36, 48, 54)
AP03             "                                        "60       Channel 11  "        "
AP03 (MAC 6E)
channel agility: No
Network mode: Infrasture
Preamble: long
#STA#: 0
PCF/DCF: DCF
Cell Power: dBm 17
APO3 (MAC 61)
channel agility: No
Network mode: Infrastruture
Preamble: short
# STA: 0
PCF/DCF: DCF
Cell Power: dBm 20
I have set the radio policy to "all"  so it can operate at 2.4 & 5 GHz Range (What should it be set at?)
I have two alerts
1) AP PHY data rate anomaly: user date rates of 48M and 54M is not included in the user defined date rate
2) Missing Performance Options: does not support 802.11b optional capability (/packet-binary-convoltional coding/channel agility)
I'm also showing overlapping legacy BSS condition exists on channels
1) beacon legacy BSS on channel 9 2.4 GHz within range of an HT (20 MHz) AP on channel 13, HT (40 MHz) on channel 13 & HT (40 MHz lower)ch 14
2) "                                      "channel 6 2.4 GHZ "                                                              "channel 10  HT (40 Mhz) on channel 10 & HT  (40 MHz Lower) ch 14
3) "                                     " channel 1 2.4 GHz "                                                               " channel 5  HT (40 Mhz) on channel 13 & HT (40 MHz Lower) ch 9
How do I seperat by operating channels?
Saravanan Lakshmanan
don't use 40mhz for 2.4ghz radio.
40 MHz can not be enabled for 2.4 GHz radio.
It was available to bet set earlier ( I don't remember the verion) but now with latest 3 code versions it is not possible.
Is channel width configurable under 802.11b/g/n radio with 7.0.98.0 that you use?
Rating useful replies is more useful than saying "Thank you"
