packetfence Captive portal issue
mohdhafiz4029ff
Hi ,
I have configured the packetfence according to guide , but when i go to connect the SSID. its directly connect and reach the internet and not redirected toward web auth page.
i cant find any logs and anything else to troubleshoot. pls check my config which i have shared in snapshot and suggest
Hafiz
marce1000
 - There are no attachments in your post  , what controller model are you using (including software version) ?
 M.
Cisco 5508 controller, software version 8.5.171.0.
  - Checkout the controller configuration using WirelessAnalyzer input (procedure) for AireOs controllers and
    feed the output from that into Wireless Config Analyzer
  - Debug the clients needing captive portal according to https://www.cisco.com/c/en/us/support/docs/wireless/aironet-1200-series/100260-wlc-debug-client.html
     You can  have client debugs analyzed with  Wireless Debug Analyzer
  - As per https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html
             use 8.5.182.11
             which is strongly recommended since the 5508 is EOL (use last/latest release available)
 M.
Rich R
And refer to the web authentication guide: https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wlan-security/115951-web-auth-wlc-guide-00.html
