PEAP Client Authentication Problem WLC 9800 AP9115 Flex connect mode
friedelkg
we have a problem with client authentication
I started "debug client [MAC] on AP, but I can't find any output despcription.
debug client a893.4a02.c15f
[1718176130:834361] [LDBV-Freyung-38] [a8:93:4a:02:c1:5f] <apr0v0> [U:W] DOT11_AUTHENTICATION : (.)
CLSM[A8:93:4A:02:C1:5F]: US Auth(b0) seq 4 IF 23 slot 0 vap 0 len 30 state NULL
CLSM[A8:93:4A:02:C1:5F]: DS Auth len 30 slot 0 vap 0
CLSM[A8:93:4A:02:C1:5F]: Driver send mgmt frame success Radio 0 Vap 0
CLSM[A8:93:4A:02:C1:5F]: client moved from UNASSOC to AUTH
[1718176130:835877] [LDBV-Freyung-38] [a8:93:4a:02:c1:5f] <apr0v0> [D:W] DOT11_AUTHENTICATION : (. )
[1718176130:836215] [LDBV-Freyung-38] [a8:93:4a:02:c1:5f] <apr0v0> [U:W] DOT11_ASSOC_REQUEST : (.)
CLSM[A8:93:4A:02:C1:5F]: US Assoc Req(0) seq 5 IF 23 slot 0 vap 0 len 188 state AUTH
CLSM[A8:93:4A:02:C1:5F]: DS Assoc Resp(10) IF 0 slot 0 vap 0 state AUTH, generated by AP
CLSM[A8:93:4A:02:C1:5F]: client moved from AUTH to ASSOC
CLSM[A8:93:4A:02:C1:5F]: [handle_hapd_failure] association error status 43 , Send Deauth
[1718176130:840044] [LDBV-Freyung-38] [a8:93:4a:02:c1:5f] <apr0v0> [D:W] DOT11_ASSOC_RESPONSE : (. )
CLSM[A8:93:4A:02:C1:5F]: Send Deauth - Radio 0 Vap 0 success
CLSM[A8:93:4A:02:C1:5F]: Client delete initiated with timeout of 3 seconds
CLSM[A8:93:4A:02:C1:5F]: Remove success from ClientIPTable on apr0v0
CLSM[A8:93:4A:02:C1:5F]: Sent DELETE_MOBILE with reason CLIENT_DEL_SUB_CLSM_ASSOC_RESP_WITH_FAILURE_STATUS(278)
CLSM[A8:93:4A:02:C1:5F]: client moved from ASSOC to DELETE_PENDING
[1718176130:948065] [LDBV-Freyung-38] [a8:93:4a:02:c1:5f] <apr0v0> [U:W] EAPOL_START
[1718176130:948542] [LDBV-Freyung-38] [a8:93:4a:02:c1:5f] <apr0v0> [D:W] DOT11_DEAUTHENTICATION : (.)
CLSM[A8:93:4A:02:C1:5F]: Delete timeout
Can anyone help me to find the reason?
regards, Thomas
Mark Elsen
 - You can also engage on client debugging on the controller using :
                     https://logadvisor.cisco.com/logadvisor/wireless/9800/9800ClientConnectivity
   The resulting client debugs (so called RadioActive Traces) can be analyzed with Wireless Debug Analyzer
 - Have a checkup of the WLC 9800 configuration using the CLI command show tech wireless
    and feed the output from that into Wireless Config Analyzer
 - What software version is the WLC 9800 running ?
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
friedelkg
Hi Marc,
thanks for your response.
We could find the reason:
handle_hapd_failure] association error status 43  - Invalid AKMP - explained in  https://community.cisco.com/t5/wireless-mobility-knowledge-base/802-11-association-status-802-11-deauth-reason-codes/ta-p/3148055
On WLAN SSID we allowed  FT + 802.1x as Auth Key Mgmt only. Now we enabled 802.1x as well and it works.
Regards, Thomas
Rich R
That's what Cisco call Mixed Mode - see https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/technical-reference/c9800-best-practices.html#Enable80211rFastTransition
