PEAP-MSCHAPv2 & MAC-AUTH with WEP on same AP
jorge.s
is it possible to have PEAP-MSCHAPv2 authentication and MAC Authentication against Central Cisco ACS, on the same Access Point on different SSID's without conflicting with each other?
Jorge
rnigam
The answer would depend upon the configuration done on the AP..
a) if you have configured vlans on your AP then you can set SSID , map it to each vlan and accordingly configure encryption to each vlan
b) if there are no vlan then too the two ssid would work but you then you have to have the same encryption on both the ssid.
