Per-site RRM freeze in 9800 WLC
vodovozovilya
Hello experts, I am wondering if there is an option to freeze RRM (DCA and TPC timers) on a per RF-tag basis? Could not find it on 17.12 code version neither in GUI nor CLI. I saw this Freeze option only in Configuration > Radio Configurations > RRM > 5GHz > DCA, but looks like it is going affect all APs in all the offices. Looking for a way to freeze DCA/TPC in desired locations only. All APs are in FlexConnect mode. Thank you in advance.
Make new site add AP to it and add rf tag without RRM
MHM
marce1000
   - Check if this can help : https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/config-guide/b_wl_16_10_cg/radio-resource-management.html#overriding-the-TPC-algorithm-with-minimum-and-maximum-transmit-power-settings
 M.
Leo Laohoo
Hard-code the Tx power and channel assignment of each AP.
vodovozovilya
Thank you guys for your replies.
Seems that there is no option to do it in one click and it gets to statical assignment of channels/power, and then reverting it back again, which sounds a bit complex.
@marce1000 , thanks for that doc you've shared, I finally found there a command to see APs' power levels on 9800 - show ap name <name> config slot <0|1|2|3>
I liked that AireOS WLCs were showing those levels with show advanced 802.11a txpower and I thought in 9800 you cannot see them
