Per SSID ACL's on 9800; Where to apply
David Ritter
Level 4
Level 4
I have multiple SSIDs that share a common vlan interface to the outside that require SSID specific restrictions.  In AirOS, the ACL's are applied to the SSID/wlan in the advanced/interface overide ACL spot.  But I don't find such feature in IOSxe (17.9.3).
Any Ideas?
Rasika Nayanajith
Hi David,
Did you check under "Policy Profile > Access Policies > WLAN ACL" to see if that helps
Rasika
*** Pls rate all useful responses ***
David Ritter
Level 4
Level 4
Found it,  (again) thank you
