Performance
aksher
Level 7
Level 7
The scanner communicating to the AP is facing slowness in scanning.How to check , sort out performance issues on AP.
Scott Fella
If you want to check out performance issues on the AP, associate to the ap with a laptop and if possible, run the telnet emulation on your laptop also. Other than that, you have performe your basic troubleshooting.
-Scott
dennischolmes
Level 11
Level 11
Slowness could be an indication of poor RF signal quality or interference. Have you had the area in question surveyed? If not, look for multipath, noise, and cochannel interference. I am betting if you use Omnipeak Wildpackets that you will see multiple retries. If this is in fact the case, you need to find the reasons why.
