permission denied when trying to delete or rename in bridge: mode
scanaan
i got a cisco 1310 aironet with a forgotten password.
i am trying to follow pw recovery which calls for renaming the config.txt and env_vars.txt in bridge mode (like romon).
when i try deleting or renaming it gives me unfound /  permissions denied.
[as a different approach i tried loading a new image via tftp but ran out of space,
that doesnt overwrite the existing image it seems just writing the tar to the available flash space.]
heres the output:
bridge: dir flahs:
unable to stat flahs:/: permission denied
bridge: dir flash:
Directory of flash:/
2    -rwx  3852      <date>               private-config
3    -rwx  277       <date>               info
4    drwx  256       <date>               c1310-k9w7-mx.123-7.JA3
145  -rwx  4450      <date>               config.txt
146  -rwx  316       <date>               env_vars
147  -rwx  3096      <date>               private-multiple-fs
148  drwx  64        <date>               c1310-k9w7-mx.124-3g.JA1
2736640 bytes available (5004800 bytes used)
bridge: rename  config.txt oldfig.txt
rename: no such file or directory
bridge: delete  config.txt
Are you sure you want to delete "config.txt" (y/n)?y
File "config.txt" not deleted -- permission denied
Stephen Rodriguez
Try to do it like this:
bridge: rename flash:/config.txt flash:/oldfig.txt
in rommon/bridge, you usually have to call the directory you are wanting to look into or change.
HTH,
Steve
Please remember to rate helpful posts
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Stephen Rodriguez
HTH,
Steve
HTH,
Steve
brilliant, works, thank you!
