Roaming/LDAP on SIP Phone WIFI WIP310
gguerin94
we have bought some wip310 sip phone wireless. When testing them on a multiple APs network
(same ssid, same channel, AP in mode WDS), we realize they don't support changes of AP !
we have tested roaming with iphones and it works very well, sip/rtp communication are not cut.
Software version is 5.0.12 and hardware R03.
So when you think that roaming will be supported on this phones ?
soon...
About corporate directory, wip310 are comptabible with ldap protocol ?
Stephen Rodriguez
Gerald,
     From the data sheet, it does not look like the WIP310 supports LDAP, as it only supports WPA/WPA2 personal, WEP and WPS for encryption, none of which support 802.1x.  Also the phone does not support roaming, it is designed for a single AP deployment for SMB deployments
     http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps10033/ps10041/data_sheet_c78-502697.html
HTH,
Steve
Please remember to rate helpful posts
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
