pinging problem
yoyo_the_king
Level 3
Level 3
i have wds ap1200 and 4 other ap.
i configured them with the same ssid and the same gatwaye.
my probem is when client is associate with wds ap it can ping all device in network and all ap and he has internet.
but when he is associate with another ap he cannot ping any device and he has'nt internet and he cannot ping the ap who is associated with.
i don't know what is problem.
help pls.
8 Replies 8
yoyo_the_king
Level 3
Level 3
any help pls.
Are you using a WLSE?
yes i use it.
Do you have a WDS dedicated for the task or are you trying to use a client connected AP?
i configur one ap as wds and 4 other as infrastructure ap.and their authentication to wds ap passed successfuly.
if client is associated with a wds ap he ping all other ap and he has internet.
but if client is associated with other ap he can't ping any one.
Are you using all Cisco APs? The WDS should be an ethernet only AP if memory serves me correct.
yes all ap are 1200 Cisco.
and i configure the same gatwaye in all ap.
