Please Help
ChikeBrown7363
Frequent Visitor
Frequent Visitor
Please I need you guys help. I am trying to install webauth third party certificate on our wlc controllers but I get error code 13 and 12.
My question is this, can I generate a csr from one of the wlc controllers, submit it to the CA and import the CA certificate on all our wlc controllers without issues? I don't want to use openssl.
I will appreciate urgent response.
First Rule: If it is urgent, then open a TAC case. All people helping here do that in their free time.
If you want to use one certificate on multiple WLCs, the easiest way is typically to generate the CSR with openssl (which is also available for Windows). When you generate the CSR on the WLC, the private key is on *that* WLC. The certificate that you get from the CA only has the public key, but you need to import the certificate with the private key to the other WLCs.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
5 Replies 5
Grendizer
Google Chrome will not accept any cert without SAN field in the cert which we don’t have that when we do the CSR from the WLC.
Some CA allow to insert SAN fields but will cost a lot more.
also, As explained in the AireOS WLC HA SSO deployment guide, certificates are not replicated from primary to secondary controller in a HA SSO scenario.
so you have two options:
Option 1
With this option we will generate the CSR file from the WLCs (Active and Standby in case HA SSO):
Pros:
1) The advantage with this option is that the key is generated on the WLC and never leaves the WLC thus is never exposed to the outside world.
Cons:
1) Need to generate the CSR file from both Active and Standby WLCs "in HA SSO case".
2) Need to have two separate certificates from public third party CA.
3) This method does not allow to configure Subject Alternate Name (SAN) in the CSR, as a workaround, some CA allow to insert SAN fields at signing time, this has to be done to insure that Chrome clients can see the portal with this cert because Chrome version 58 and later does not trust the Common Name of the certificate alone and requires Subject Alternate Name (SAN) to also be presented.
4) More expensive because you will need two certificates with SAN config.
5) In case of RMA, the new WLC need to have the same above steps.
6) WLC Virtual interface “DNS Host Name” need to be configured and this name has to match the common name in the CSR file. DNS team has to populate that name in the DNS so clients will be able to resolve that name even from public DNS servers “if Guests will be using public DNS Servers”, although, the portal itself will not be showing for anyone in the internet except those will be connected locally.
Option 2
With this option we will generate the CSR file from the OpenSSL program:
Pros:
1) Generating the CSR for the primary WLC with OpenSSL and therefore the key will be attached to the certificate and can be imported "that certificate/key" combination on both WLCs.
2) One certificate needed from the public third party CA instead of two for the HA pair.
3) This method allows to configure Subject Alternate Name (SAN) in the CSR file.
4) Less expensive because you will need one certificate.
Cons:
1) Less secure than option 1 because the key will be exposed to the outside world. (example: The PC that will be used with the OpenSSL will have a copy of the certificate private key)
2) Installing OpenSSL.
3) In case of RMA, the new WLC need to have the same above steps.
4) WLC Virtual interface “DNS Host Name” need to be configured as previously explained.
General Notes for both above options:
1) if you already have the WLCs in HA then you can do either the below:
a) Break the HA completely to install the certificate on both WLCs and reform the HA, or
b) Issue a command redundancy force-switchover on Active controller, when complete the certificate installation do that command again to switch to the Active one again.
2) Using the local WebAuth need to be combined with enabling HTTPS redirection feature or you will see problems, which mean the WLC has to run 8.8.130.0 or 8.10.x code. (this is for WLC performance reasons which was implemented from WLC code 8.7 and later).
3) A certificate warning is unavoidable in case the client request to open a web page manually to get to the AUP portal because if the client requests any URL (such as https://www.cisco.com), the WLC still presents its own certificate issued for the virtual interface IP address. This will obviously never match the URL/IP address requested by the client and the certificate will not be trusted unless the client forces the exception in the browser. Most today’s client’s devices (Smartphones or PCs) have a way to check that using their hidden websites to check connectivity, for example, Apple iOS will check with Apple website dedicated for this purpose (http://captive.apple.com/hotspot-detect.html) to present to the user the login portal (AUP portal), this is done by http traffic. Same thing for Firefox, (http://detectportal.firefox.com/success.txt) and similar method and links for other browsers, in these “http” cases the client will not see certificate error.
Openssl:
You can download and install Openssl version 1.1.1h from the internet, it is free.
After installing OpenSSL on a PC, go to the OpenSSL location (for example:C:\OpenSSL-Win64\) And then open the “cnf” folder inside the “bin” folder and right mouse click on openssl.cnf file and open it with Notepad or better with Notepad++ (Notepad++ is free also)
Make these important changes:
1) Uncomment req_extensions = v3_req line
2) Under [ v3_req ] Section add:
subjectAltName = @alt_names
[alt_names]
DNS.1 = anyname.yourcompanyname.com
DNS.2 = anyname2.yourcompanyname.com
Note: you can have one name or multiple names in above, so if you have multiple WLCs and wants all of them using the same WebAuth cert you need just one name and then from the DNS resolve that name to your virtual IP address (which is the same for all WLCs), example anyname.yourcompanyname.com = 192.0.2.1
Note: (((VERY IMPOTANT))): One of the DNS names above "which they are the SANs" MUST be the same name as the CN (Common Name) that will be used when generating the CSR, this is important for google chrome clients.
3) save the file
4) open the “bin” folder and right mouse click on openssl.exe and click “run as Admin”
5) Generate the CSR with:
req -out anyname.pem -newkey rsa:4096 -nodes -keyout anyname-key.pem -config "C:\OpenSSL-Win64\OpenSSL-Win64\bin\cnf\openssl.cnf" <-- replace the windows path and then complete all the required info
6) Make sure to keep your private key file secure.
7) To verify the information and the SANs, close the openssl and reopen it again (needed to avoid a bug in Openssl version 1.1.1h)
😎 After opening a new openssl.exe as Admin use the below command to verify the CSR file:
req -text -noout -verify -in anyname.csr
9) If everything is ok, provide this CSR to the CA to have it signed and receive a certificate back.
10) When you receive the cert from the CA, open the final cert file (that you received from the CA) in a notepad and make sure the order of the chain certs as below:
------BEGIN CERTIFICATE------
*Device cert*
------END CERTIFICATE------
*Root CA cert *
Or like this if you use cert with Intermediate CA cert:
*Device cert*
*Intermediate CA cert *
------END CERTIFICATE--------
*Root CA cert *
If this need to be changed then just reorder them as above (copy/paste) and save it in a new file as name.pem if it’s not already in this format.
now we need to combine the key (the private key file) with this cert using:
pkcs12 -export -in anyname-chain.pem -inkey anyname-key.pem -out anyname-chain-with-key.p12
Convert the cert from .p12 to .pem using:
pkcs12 -in anyname-chain-with-key.p12 -out WebAuth-Final.pem
Side Note: for users that wants to test that with Windows Server CA, Windows by default will generate the cert as .p7b to convert it to .pem use:
pkcs7 -print_certs -in certname.p7b -out certname.pem
and then combine the key (the private key file) with this cert using same above commands
11) once you have the final public cert, you need to download it to the WLC, you need to download and install certificate using CLI because of CSCvv72578 https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvv72578
example:
transfer download mode tftp
transfer download datatype webauthcert
transfer download serverip x.x.x.x
transfer download path /
transfer download filename WebAuth-Final.pem
transfer download certpassword yourpassword
transfer download start
12) reboot the WLC
13) verify the new cert from SECURITY > Web Auth > Certificate
So my summary of Karsten and Grendizer's replies:
My question is this, can I generate a csr from one of the wlc controllers, submit it to the CA and import the CA certificate on all our wlc controllers without issues? NO
I don't want to use openssl - OpenSSL is your only option if you want to deploy the same cert on multiple WLC.
And Grendizer has kindly provided detailed info on how to do that.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
yes, that's correct
ChikeBrown7363
Frequent Visitor
Frequent Visitor
Thanks to everyone for the inputs. I have finally generated CSR using openssl and imported the CA Certificate to each WLC successfully.
