POE Power
jreddick
Community Member
Should the POE Power be constant. I have several AP's that are fluctuating from 9.4w to 16.4w, just want to know if this is normal
6 Replies 6
balaji.bandi
what model of AP ? can you post some examples. have not seen any time before these kind of variations
BB
MR53
Philip D'Ath
Meraki Community All-Star
Yes, the power draw will vary on the MR series while it is in operation.
Looks that is expected behavior i guess, i see on our environment when I run the reports the same.
BB
Thank you
JPavonM
Is it the AP connected to a MX or MS device? I have noticed some PoE issues in MX as it is not LLDP-Med compliant, this is known behavioiur and apparently Meraki is not going to fix it.
