Poor Access Point Performance-AIR-AP1832I-E-K9 with 5508 controller
niyasv6675
    I am facing poor wireless performance in my network.The AP performance in Local and Internet also very slow.
I am using Cisco AIR-AP1832I-E-K9 Accesspoint with 5508 controller.
PLEASE FIND THE ATTACHMENT FOR DEATILS.cONTROLLER.TXT IS THE CONFIG(cfg) FILE
alindzon
I just installed the AIR-AP1832I-E-K9C model which uses an internal controller.  When running OOKLA tests from a samsung android phone or a MAC notebook, with the access point connected directly to the router, we get half the performance of the 802.11n wireless that is built into this residential router.
Clearly there is something wrong with the performance of these access points, a setup issue, or a bug in the firmware.
Has anyone made any progress with the poor performance? I am also getting very poor performance on my AIR-AP1832I-B-K9 WAPs when there are multiple connections.Very poor performance.
No Progress
Any progress?
I have a similar problem.
https://supportforums.cisco.com/discussion/13233816/ap1832i-5ghz-channel-noise
