Poor signal strength with 350 bridges
aichafe
I have a point-to-point link with 2 350 bridges 10miles apart. I use two directional antennas for the link. The bridges were set to a data rate of 2mbps. The links worked very well for about 6 months. Of recent I started to get signal loss until I changed the data rate to 1mbps before the signal came back. I am now afraid this may repeat itself.
Kindly help.
Chafe
ndoshi
Hi ,
I assume you must have you link budget calculator and have antenna at proper height .
http://www.cisco.com/warp/customer/102/wlan/radio-faq.html
Use Antenna Alignment and Link test to do antenna alignment and to get
clean channel .
Possible some interference issue also . Jump to another channel and see if it helps
Nilesh
mustafa.mail
go to 350 bridge non-root bridge:
setup-network nodes-radio - hardware
data rate enable for -11 - 5.5 - 2 - 1 Mbps
network- dionastge- antenna aligment test
then make your aligment.
James Strong
Are your outside connections properly sealed with Coaxseal? Water in the cables will causes major problems.
