Power Injector Issues
shreemahida
Community Member
The power injector I am currently using (Model: DPSN-35FB A) has a blinking green LED for AP Power and a solid green LED for AC Power. I'm not sure if this is supposed to happen or if there is something wrong with the power injector.
Appreciate the help
8 Replies 8
jamesbos96602
Level 3
Level 3
i found on some power injectors that pins that send power they change.
throw i not shure but i removed wires from pins 5,6,7,8 and unit powers up
this sujest that power is sent on pins one throw 4
i have confirm that two of wires are carrying voltage
so how cable is wired is most imported
u can not use cross over cable between the injector or ap
i can not confim this is case for all units,
only ones i have. but would make sence that cisco would do everything the same
now i not sure if power sent on all 4 wires or just two , i not gone so far,
i shut down the swich as got to cold to work on
but something to consider
i confirm that cisco uses pins 1-2 -3 -4 for power  u can not use a cross over cable,  5-6 7-8 is use for data ,
no other company dose this that meens  must be cisco device unless u change the cable
now it might need cross over cable from swich to poe  i seen this as well
but from poe to ap wires  must be stait throw
Scott Fella
Does the power injector work?
-Scott
if he has lights it working quistion becomes if he has right cables for it , some times a crossover cable needed befor the injector some do not requre this but u never use cross over cable after the injector u burn something out
I never seen a power injector that uses a crossover cable.  How I understood the question is if the blinking lights were okay, so yes, the power supply has power to it, I want to know if the ap powers up or not.
-Scott
i have had units requred cross over cable  but u got flashing green light it not the injector, it in the cables or there is reason why
the data is not going to device,  wifi up . dose this wifi use a controler to run it , or is it stand alone
probem is it not linking or getting dhcp , where i start is reset the wifi, if that fails replace bouth cables,. if  that fails then replace injector , if it like to a controler probem is in controler and i run debug commands see if anything pops up
some wifi requres a encripted channel as u not stated how this wifi is set up or show logs of wifi best we do is guss
Scott Fella
@shreemahida does your ap power up?
-Scott
Ap powers or light not be green sound like not getting data or encryption not same
willing bet it working on dhcp
and not getting dhcp addresses
but without debug logs every thing said Gus’s work
sold green light when unit a) has static ip and can access the gateway or b) until on dhcp
wich until waiting for dhcp ip assignment
c) one or both cables has problems of some kind
d) encryption dose not match the dhcp server and or gateway
