power local
Chieu Dinh
- How can I set the power local to more than 12? I am only can set my power local to 12 or Max however I can see it is available for 12, 18, 21, 23 ,,,,,
- I run show controllers dot11Radio 0, it shows the current power is 0.
Any ideas?
17 Replies 17
Chieu,
Yes, you can send them to me. I think you just need to click my username and then you should see an option to send a private message.
Justin
I sent you both root bridge configuration and non root bridge configuration.
What kind of controller and APs?  Have you recently upgraded your firmware?
Check this out and see if it looks familiar:
https://supportforums.cisco.com/thread/2046217
Ven
Ven Taylor
