power over ethernet for AIR-BR1310G
ELIE IBRAHIM
Hello
i have AIR-BR1310G that came with its proper power injector AIR-PWRINJ-BLR2 can this power injector be feed using a POE switch or do i have to use the 48v power adapter
regards
Elie
Amjad Abdullah
ELie: no PoE. You can only use power supply to operate the bridge.
Amjad
Rating useful replies is more useful than saying "Thank you"
Amjad Abdullah
Amjad
