Power Over Ethernet (PoE) not working on WLC 2504
bvj197222
I have connected a 2602 AP to one of the PoE-ports on a 2504 WLC running ver 7.5.102.0. But there's no PoE going to the AP, and it doesn't turn on. There's probably something I have misunderstood here so sorry for asking this stupid question, but why doesn't it work? I checked out controller>ports and all interfaces are there but no PoE.
Scott Fella
PoE is not available if you have LAG enabled only if it's disabled.
-Scott
Scott ,
I think lag not supported on 2504 WLC , is it correct ??
Cisco started supporting LAG on v7.4 which is what a lot of customer wanted. However, PoE gets disabled when LAG is enabled, so it's sort of a trade off.
-Scott
Sandeep Choudhary
Normally port 3 and 4 are the POE ports on 2504 Wlc.
Check it again if it is right ports.
