Prefer 802.11a over 802.11g within SSID - Is it possible?
Daniel Anderson
Currently have a corporate SSID advertised enabling clients to connect using either A or G. Ideally I'd like clients too connect using A if they're able, and if not connect on G.
I think I've read on these forums this is possible but requires the WLCs to be running specific (quite new) firmware.
Is anyone able to advise?
TIA
ericgarnel
Level 7
Level 7
Yes, you can try to make 802.11a more attractive by tweaking the rrm values on the controllers.
For example:
my tpc values for a are:
Tx Power Level Assignment Algorithm
Power Threshold (-80 to -50 dBM) -67
and only have 36, 40, 44, 48, 149, 153, 157, 161, 165, 26 channels enabled
for b:
Power Threshold (-80 to -50 dBM) -70
You can also choke back on the basic rates for b/g depending upon your density.
If your environment allows you to control the clients, you can also tweak the network card settings on the clients to prefer a as well.
rduke
I have not tested this in a while so I don't know if Intel fixed it. Where I used to work, I had the same SSID on a and b/g radios. When using the Intel Proset client and the Intel 2915 adapters, the computer would connect to the "a" radio, you could then turn the laptop radio off and on (function-F2 on a Dell). Then it connects to the b/g radio. Every time you turn off the radio, it would toggle between the a and b/g radios. They may have fixed it by now, and I don't know if the same thing happens when using Windows wireless zero config. You might want to test it to see if you have this issue. I can't test that easily where I work now.
Randy
