Preventing How to Crack a Wi-Fi Network’s WPA Password with Reaver
slwdaw_2
Are Cisco AP's vulnerable?
http://lifehacker.com/5873407/how-to-crack-a-wi+fi-networks-wpa-password-with-reaver
Is their a new IOS available to handle this?
12 Replies 12
Leo Laohoo
If you mean a dictionary attack to crack your password, then yes.  EVERY manufacturer is vulnerable.  If you practice good choice of passwords, then it will take time for Reaver to punch through.
George Stefanick
WPA and WPA2 "PSK" are susceptible to this issue. If an attacker captures the 1 and 2 or the 2 and 3 part of the 4 way handshake they can then use tools like COWPATTY or REAVER to crack against a dictionary.
What is important, dont use a KEY that will likely be in a dictionary.
So I can't use passwords like "password" or "youcantcrackthis" can I?
Follow the "rules":
1.  Mix upper and lower case;
2.  Use numbers;
3.  Use common sense:  Passwords like "love", "password", "admin", etc is the first few words to be tried by crackers.
Love, really ? Who uses "LOVE" ... Only Leo ...
ha ha ha
Surendra BG
Too funny:)
Scott Fella
Sent from my iPhone
-Scott
Leo must have been watching Hackers again!
To piggy back on George:
Cisco AP's do not use WPS, so they should not be vulnerable to this type of attack.
The Linksys side of the house however, can/does use WPS.  you might want to hit the SMB forums and ask if they are aware of, and have a way to mitigate such attackes.
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
LOL!
BTW -- That  program only cracks WPS, not WPA. WPS is used on home router wifi units.
here listen to this blog video
http://nostringsattachedshow.com/2012/01/08/e02-wi-fi-protected-setup-battered-or-broken/
You are partly right here George. Granted, Reaver 'only' cracks WPS PINs, but once it has done so you are 'given' the WPA/WPA2 PSK. In a round about way you are ultimately getting your goal, the WPA/WPA2 PSK.
A Reaver attack tutorial/demonstration using the OG150 is now available to download for free! WPA2 PSK WAS CRACKED IN 4 SECONDS!! Download the PDF tutorial from http://www.og150.com/tutorials.php.
Attack was demonstrated on a Linksys WAG54G2 router with v1.00.10 software.
Darren
Abhishek Abhishek
As per your query i can suggest you the following solution-
Yes Ap's are vulnerable. You can use encryption, PSK,WPA.
Secure your SSID broadcast.
Mix characters and use numeric and alpha-numeric.
For more information you can refer to the link-
http://www.giac.org/paper/gsec/4094/securing-cisco-aironet-1200-access-point/106589
Hope this will help.
