preventive maintenance WLC 4400 and 5500?
Logan1989
Hi good morning,
i asking for help in order to make a preventive maintenance for WLC 4000 and 5500.
the main problem is: can i open the WLC´s and clean all the circuits they have inside? or must i only cleaning out the WLC?
And i would like to know if there are documentation about this topic.
thanks.
Sandeep Choudhary
HI,
I dont know what you wanted to ask related to maintenance but still suggest you :
If you are not professional then dont open the wlc parts from inside. Just clear sirt from outside.
YES if you have enoght knowledge about inside circuit then go ahead.
Dont forget to rate helpful posts
thanks
I thought of opening the WLC, and use compressed air to remove dust only.
but like you mention would be better not open it.
Greetings
