Prime 1.3 CSR creating problem
Dear all,
i created a new reposiroty:
and tried to create a CSR to that reposiroty..but i got the follwing error message.A file was uploaded but with 0KB..
repository CSR
  url tftp://x.x.x.x/
Generating RSA key
Writing certificate signing request to /opt/CSCOlumos/migrate/restore/server.cert
INFO: no staging url defined, using local space.        rval:2
Transfer timed out.
ERROR: Upload of server.cert failed.    rval:-302
ERROR: ncs key genkey command failed.   rval:-302
CPI/admin#
was there something wrong ot is it a BUG.
regards,
Sebastian
6 Replies 6
Scott Fella
Use the keytool:
http://www.cisco.com/en/US/docs/wireless/prime_infrastructure/1.3/configuration/guide/hard.html
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Hey Scott,
how does it work? I know only the ssh CLI or the webgui..
Do you have a little bit morde details for me pls?
regards,
Sebastian
Seems like it might still be an issue... I ran into this thread.  Maybe open a TAC case up with Cisco if you still want to create a CSR using PI.  I typically use OpenSSL v9.8.x to generate my CSR's.
https://supportforums.cisco.com/thread/2132859
Scott
-Scott
all right Scott, thank you very much. I will also try to use another system for it .
regards,
Sebastian
UPDATE,
the CSR creation works!
the problem was on my repository, this is my PC and there was a policy update of my personal firewall from the client team installed whoch blocked the FTP upload in a strange way...
So it seems to be not a bug ot something else...everything is fine..
It's always something on the corporate machines:)
-Scott
