PrimeInfra not showing correct clients info from WLC
Wireless_Guy
Hi All,
Its been noticed the PrimeInfra is not showing the correct clients information from WLC when doing a live thsoot. Has anyone noticed this issue before and is there any fix for it ?
Hi @Wireless_Guy
Try to sync up Prime and WLC and perform audit just to make sure. It is also a good idea stop/start Prime services sometimes.
 But if this is a bug, only through a TAC you can address this.
-If I helped you somehow, please, rate it as useful.-
Hi @Flavio Miranda
I'm planning to check the polling confi. However from Cisco PI document it says "If you receive a message that the client does not seem to be connected to any access point, you must reconnect the client and click Refresh."
Administration > Settings > Background Tasks page
Administration > Settings > System Settings > Client and User > Client
https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-1-3/user/guide/pi_ug/clientmgmt.pdf
I am afraid that it is not that easy. More than once I´ve been connected in some access point and later on tried to find myself on Prime and there was no record.
Unfortunately Prime has lots of problem.
